crossflow heads on a 280??
Guest
Posts: n/a
Re: crossflow heads on a 280??
Where are you? In adelaide, i've been to Adelaide Z cars looking for electronic distributor for my 240, they have a few 280zx's, i don't know about heads. It seems as soon as they get something decent they sell it... you could try them. Also in adelaide Japanese motorsport imporst fuel injected L28's (i think) you could try them. Iwould look in the yellow pages and just ring around wreckers, you never know your luck.....
SSS automotive in NSW import L28 injected, so they might be able to help or or try www.ichiban.com.au- they import lots of nissan engines, they might be able to help. I hope this helps you
Alan, Australia
Alan, Australia
Guest
Posts: n/a
Guest
Posts: n/a
sorry, but they are aussie places. They might still be able to help you, you might be more successful wit hamerican wreckers... still worth a try though as they could definitely point you in the right direction
Alan, Australia
Alan, Australia
Guest
Posts: n/a
Cross flow heads were made for the S20 engine which has 24 valve per cylinder and one of the tuning houses in Japan made a cross flow head kit in the seventies which was very expensive and I have only ever seen a line drawing of one - rare as hens teeth.
If you want a cross flow head then you could always repower the car with a RB25DE...........
TWM throttle bodies with nice headers on the other side - hmmmm nice.
Cheers
Glenn
Cheers
Glenn
Guest
Posts: n/a
Yeah-the head is an extreme rarety that was bolted on the 2 Liter inline 6 engine on a series of fairlady z's in Japan. It was dicontinued because of bad problems with cam vibration due to design. About a month ago I talked with a man that had one and wanted a little over 2 grand for it. I think the money would be better spent otherwise.
Guest
Posts: n/a
So whats the deal with swapping in a RB series motor?? Im in America so i can already see how much it would cost! But i hear they have nearly identical motor mounts and should be pretty straight forward with the installation. What kind of tranny could you use with it?? Anybody ever thought of seeing how hard it would be to swap in chevys new inline 6??
