drum to disc conversion
Welcome to ZDriver!!!
Clicky and open your pocketbook (or you can DIY): http://www.arizonazcar.com/rearz4luginstall.html
I have a 1973 240Z with a bad engine & a 1978 280Z parts car that I am planning to pull the engine & trany out of and drop in the 240, but I've never done it before and the 280 isn't running just yet, ithink the injectors are bad.
Runs on gas poured in the intake though....
why would you need to change struts? are yours shot if so replace but im sure your asking about strut tubes. if so then no you dont. rear rotor from a 280zx magically fits a rear hub on a s30 after all its drum brakes have been taken out. they are both 4 lug
You do know MSA makes a bolt on kit for like $300-$600 right?
EDIT: Sorry more like $400 to $1000 http://www.thezstore.com/page/TZS/CTGY/PBC12
I'll throw in my $0.02. I used the Modern Motorsports kit(s) for both front and rear. The rear is the 300ZX rotor, 240SX caliper option: https://www.zdriver.com/forums/240z-260z-280z-brakes-wheels-suspension-chassis-126/pics-modern-motorsport-rear-brake-kit-23640/
The front is also from M.M., going the 4-piston Toyota, vented rotors option. I also went with a ZX master cylinder and booster, as both my originals were shot. I don't remember if I put a thread up here about that or not.
I've had it out to two open lapping days at High Plains Raceway this year, and been extremely pleased with the performance. The brakes aren't the limiting factor. That would be me; I need to learn to drive on track better. And getting some stickier tires wouldn't hurt.
Standard Disclaimer On All Early Z Brake Discussions: The stock system, in clean and well maintained condition with all good parts will work extremely well even in more challenging conditions. That said, there are still some very good reasons to change it up, and about 30 different well known modifications (probably not much of an exaggeration). There're a bunch of discusssion in the archives here, and a giant sticky on hybridz.org, too. Anyway, I modded mine as above, and I love how it works.
cheers,
Dave
cheers,
Dave
Yes, it does use the Z31 (300ZX) vented front rotor. It looks just like in the hybrid sticky, although I had to radius the calipers with the grinder to clear my wheels. I kept grinding one until it cleared and smoothed it out.
Then I went into the kitchen (it was like 21:00 or something) and made some homemade play-doh (seriously), made a mold of the new caliper profile, cut the mold in cross-section, and made a pattern template out of paperboard, and used it to grind the other caliper to match. Both got a coat of caliper paint in silver to keep the "customized" part from corroding. Different wheels wouldn't be such a PITA, but I still like them.
Couple things I really like about this setup: 1) I can keep my stock parking brake setup. 2) My brakes don't fade at all in a 30 minute track session. Wish I could say the same about me! 3) I don't have to bleed the brakes between track sessions to keep my brakes working properly.
I'll work on getting those pics.
cheers,
Dave
In fact, one change I'm working on now is Schroth 3-point harnesses, because I'm tired of braking/steering pitching me around in my seat at the track. It's surprisingly tiring. I'd like them in by the last session in October, but we'll see. Projects have a way of determing their own timeline. Disclaimer: I am a total noob track driver, only having been out twice. The car is way better than I am. I need more practice. And some instruction wouldn't hurt, either. And stickier tires.
cheers,
Dave
You've got me thinking, I might just go ahead and pull the front wheels off to be sure I have enough pad left for one last track day before winter, and take those photos while I'm at it. Minimal work to do so, and the consequences of running out of brakes are suboptimal.
What's your time frame on your brake conversion? Is this an over-winter project, or going on now?
cheers,
Dave
I upgraded the front brakes on my 280Z to the Toyota 4-piston Calipers, unfortunately right after I finished putting them on I came across that HybridZ post showing that there was another slightly different later model of the 4-piston calipers so I could use the Z31 vented rotors... Somewhere down the line I'm probably going to use the Modern Motorsports rear disc conversion.
EDIT: After I started reading through that thread now I'm more annoyed, I see that there's a slightly more machined version of the calipers I'm using for the 300ZX vented rotors. So it'd be the same size as my 4-pistons I currently have, so it will still clear. Just a slightly larger inside. Right now I'm using my 4-piston calipers with my 15" Swastikas from my Turbo car with no issues.
Interesting it clears your 15" swastikas. I wonder if those wheels would clear my brakes? I bet I could get a set for not much money, and maybe get those stickier track tires I want...
I might even be able to trade the 14" "Dukes Of Hazard" type wheels my car originally had. Hmmm.
cheers,
Dave
zpeedracer25
03-31-2019 06:22 PM
ugly
11-06-2004 03:48 PM
