Drums to -> Disc swap
Guest
Posts: n/a
i am taking off my drum brakes because i just ordered rear disc brake conversion from modern motorsport and i can't figure out how to get the e-brake assembly from the front of the brake of. DO i just cut it off ????
Thanks for any help given
don't cut!
I have a 70 Z and I am about to put zx disc on the rear. If I understand what you mean, you need to remove the clip on the cable were the rubber coated part ends. Pry it towards the rear of the car and it will pop out. Then pull the rubber coated part away from the brake assembly and out through the slot. Then you can loosen the two nuts that secure it to the lever. There is a good picture in Clymer "Datsun Repair Hand book" I can send you a picture if you need it.
Tom
Tom
jagarcia89
05-28-2012 03:23 PM
ugly
11-06-2004 04:48 PM
