energy suspension bushings
Guest
Posts: n/a
When installing the new poly bushings in the front control arm and the rear control arm (outer set of bushings) must I remove the outer metal casing of the old bushing that I have burned out. The new bushing seem too large for them to fit inside the old outer casing? I thought that I read somewhere that I need to cut the old bushing casings out with a hacksaw, is this what I need to do?
Instructions from energy suspension are not very good at all.
Also I am going to install the Eibach pro-kit, with no instructions from Eibach, so which springs go where shorter ones in front or back? Longer ones front or rear?
Thanks Anyone,
Ray
71 240Z
Thanks Anyone,
Ray
71 240Z
I recently did this to my '70. The front control arms come out easy. The rears are a real pain. You have to use a hacksaw and carefully cut through one side without cutting into your A arm. I put it in a vise to keep it steady and cut on the A side near the welds so if I cut to deep it wouldn't matter structuraly. The old bushing acts a a brake on the saw blade making it even more difficult. Be patient and go slow so you can keep the cut parallel with the hole. Then knock it out with a punch. If your going to do the mustach bar, don't cut the bushing out, just the rubber. I made that mistake and had to make new ones.
I put Tokikos in mine with good instructions and the springs were labled. The fronts are shorter and the coils are closer together at the tops.
I bought a complete set of urethane bushings on ebay and not one bit of instuction came with it! If I would have known how hard it was going to be I would have left them with negative feedback.
Good luck and warn your lady that there's going to be some cussin!
Guest
Posts: n/a
I have done my front energy suspension on my 71z it was easy but the back is harder what I recomend is to remove the arms and get the bearings pressed out in a machine shop it will be way faster and easier. removing ruster bolts are also a pain but well worth it.
U Bushings / Grease em
Kivadog,
Don't forget to use the blue marine / trailer grease. If you don't, the new bushings will squeak like you woudn't believe. I removed the fronts just as "theramz' suggests.
I've done the front of my 70 model and will be doing the rear soon. I'm glad I read this thread because I probably would have cut my bushing races out of the rear mustache bar w/o giving it a second thought.
Guest
Posts: n/a
One more question? When I install the new poly bushings, does the thicker bushung go to the front or back on both sides of the car. I got confused after I removed the old bushings.
Thanks
U Bushing
Are you referring to the front control arm front and back bushings (one on each side of the control arm)? If so, I'm about 90% sure the thicker bushing goes on the rear which produces a larger gap to the rear of the control arm. I can take a look tonight when I get home to verify. I did mine one side at a time so I had a reference pt, so I know mine are correct.
Guest
Posts: n/a
Yes those are the ones I am working on now.
Thanks again
u bushings
I went to carfiche.com and tried to find a microfiche, but couldn't locate it. I'm just about sure you want your extra spacing in the back (up close in the front w/ the larger gap in the back) - both sides.
Bushing Suggestion
I've been really impressed with the energy suspension hyperflex kit. It ran me about $170 from a place a found on the web called "Suspension Restoration Co." All the other places wanted about $200 or more. If you go urethane, don't forget to grease them with the marine grease or they will squeak.
http://www.suspension.com/nissancars.htm
Guest
Posts: n/a
I am working on the rear control arm now, is there a trick to get the upright and control arm back together, the new poly bushings seem to be to thick?
I just looked at mine and you can't tell which is which but there was definitly a difference before I put them in. I bought the whole kit and was pissed the whole time because there weren't any instructions, just a big bag of parts.
ultrarevvin1
Vendor Specials!
01-17-2014 08:13 AM
mikeatrpi
12-10-2012 12:22 PM
Champagne
FS: 300ZX (90-96)
05-04-2011 09:19 AM
