Gas filler neck
Gas filler neck
Do I need to drop the tank to replace the fuel filler neck on a 70 240z--the one on it now is not the proper one--too short-it looks like I can get at it --would like to do it as simply as possible.
got the filler neck in
I actually got it done without dropping the tank. The new one was so fexible and pliable that I worked the mid point flange ring down low so I could get it over the tank mouth--then i sprayed it with pam and got it real slick and slid the flange up to secure it. I was told yesterday that brake cleaner is good for sliding in rubber parts--gets it real slick for a minute or so then it evaporates--i had a slimy filler neck with the pam. Alls well that ends well--now we can put a full tank of gas in it.
zeefogey in Gilbert AZ
