Is this a good brake kit?
Old 09-30-2007 | 07:59 PM
Black260z's Avatar
http://www.datsunstore.com/product_i...products_id/17
I want to get new brakes for the car. I was reading in the search about brake conversions from toyota trucks, with 300zx rotors etc. But I don't want to be changing everything, and using spacers etc..
So I found this kit here with 4 piston calipers, but no other parts need to be replaced. Has anyone purchased this kit before or know how well it works? $149 after cores is not bad. Thoughts anyone?
Old 09-30-2007 | 08:04 PM
Those are just Toyota 4 piston calipers. You can get them for $60-$80 at a parts store... or $150 on that site because they are "Brake upgrades" for the Z.
Old 09-30-2007 | 08:14 PM
entropy31's Avatar
The Cake Is A Lie!
that place is really close to me. guy has tons of old Zs. and he charges too much for just about everything. but he is deffinatley an L motor god.
Old 09-30-2007 | 08:19 PM
Black260z's Avatar
ok so they are the same thing. I read there was two different styles, a slim and a wide. the wide would rub against the rim? What caliper is that vehicle (make / year) to make it so it wont rub, and i won't need to replace the rotor with 300zx or use spacers. I searched and didnt find anything without having to do a rotor swap.
Old 09-30-2007 | 08:29 PM
http://forums.hybridz.org/showthread.php?t=104735
-pair of '86-95 Toyota 4x4 or 86-91 4runner calipers stamped S12/W on the side
A couple years ago I spent the afternoon in a junk yard & did a bunch of part swapping from various cars. I did bolt up a Toyota caliper onto an S30 and put the tire back on... looked like it fit perfectly.
Old 09-30-2007 | 08:39 PM
Black260z's Avatar
I would assume since its a toyota caliper. I will need to use the toyota pad that goes with it. correct me if im wrong.
Old 09-30-2007 | 10:07 PM
You assume correctly.
Old 10-01-2007 | 08:39 AM
theramz's Avatar
I have a present for you...
The S-12W calipers are the ones you use with the '84 300ZX rotors and a spacer to offset the rotor. The spacer is not just a big washer, it must be hub-centric or your front end will never balance.
Old 10-01-2007 | 09:11 AM
Black260z's Avatar
So I will need the S12 calipers then. I want to replace the the pads and rotors, but I want the bigger caliper and matching pads. But I want to keep the original style rotor. How can I guarantee I will get the S12 caliper and not the S12W caliper?
Old 10-01-2007 | 09:13 PM
theramz's Avatar
The numbers are on the casting. The S12W has a space about 3/4 inch wide between the pads for the vented rotors. You'll have to trim the backing plates.
Old 10-06-2007 | 11:47 AM
Black260z's Avatar
I looked up a set of calipers for a 1981 Toyota 4x4. I called a store an hour away (the only store that had them in stock) and they told me it says S12+8 on the caliper. Will this work with my original rotor? S12 will work, S12W wont work, what about the S12+8? Anybody know?
Old 10-06-2007 | 12:34 PM
if you read the thread he posted about 1/2 down youll find your answer
Old 10-06-2007 | 12:40 PM
Black260z's Avatar
my bad.. thanks
acslater9
08-04-2014 08:24 AM
JaeTee
02-04-2012 05:16 PM
Samurai-Z32TT
06-25-2011 09:40 AM
Tsuka89
06-05-2011 12:58 AM
Fast240Z
03-07-2006 05:15 PM
Quick Reply: Is this a good brake kit?
