headers
headers
ok so I've been looking and reading (finally i know) but im still having problems figuring out what the difference is between a stock manifold and headers any advice cause im getting a better exhaust and want to know if i should buy headers or not
Did you read through our "HEADERS EXPLAINED" thread ( https://www.zdriver.com/forums/240z-280zxt-s30-s130-tech-tips-275/headers-explained-part-1-a-17672/ )? It really does explain a lot... along w/ other mods, they help the motor breathe / flow better than the stock cast iron manifold.
Stock exhaust manifold:
Header:
Header:
what i don't get is that it is still six holes going from the engine to the exhaust and if it's worth it on an s30
Six holes???? Those are the exhaust ports for each cylinder... it's a 6 cylinder motor... 1 intake 1 exhaust for each cylinder... 6 x 1 = 6. And it doesn't matter if it's an S30 or S130... what matters is what you are doing to the actual motor.
I put a 6-2-1 header from MSA on my 240 and it made a big difference in performance and makes a nice sound. I added a SuperTrap muffler on it because you can adjust the back pressure by adding or removing the baffle discs. You can remove all of them for straight through flow for top end but it's really loud. 2 1/2 '' all the way back. The header comes very close to #3 intake so plan on using header wrap on all the tubes at least 12" long.
