Help me decide, V-8 or restore?
Old 05-18-2002 | 02:21 PM
auxilary's Avatar
the Dude
Re: Help me decide, V-8 or restore?
"V8's are heavy as compared to the Z . One of the most endearing qualities of a Z is it's handling. Put the V8 in and that is gone. "
Wrong! With JTR style conversion that puts the block closer towards the center, the weight distribution is a lot closer to 50/50 than it was with the stock Lseries block. and believe me, with double the HP and torque, the extra weight isn't noticeable. The stock L-block isn't exactly light either - having driven v8 Zs before I can say that with manual steering I found it easier to make u-turns with the v8 because the weight of the block does not sit solely on the front tires. Besides, a small block chevy with aluminum heads and a world class t5 (if you're not going over 280-300hp) will weigh only 100-150lbs more than the stock motor, and it'll be more evenly distributed through the chassis.
Believe me, with the proper set up, the v8z can leave an Lblock Z in the dust around track and autoX.
the_journeyman
11-15-2012 08:02 AM
The_MuffinMan25
30
04-12-2009 09:47 PM
CanyonCarver
27
12-30-2004 05:24 PM
captainmowgli
04-26-2004 07:14 PM
captainmowgli
02-27-2004 08:22 AM
