Help my sick Z.
Old 04-08-2009 | 12:31 PM
Fast240Z's Avatar
Help my sick Z.
My Z is sick . She bogs at any RPM over 4500, needs excess throttle to leave a stoplight, and idles poorly unless engine has warmed up. She also requires an excess amount of throttle when taking off from a stop. Any ideas?
Old 04-08-2009 | 01:49 PM
KasbeKZ's Avatar
Pr0n Addict
how does it sound? it'd check the timing and make sure that it's firing on all cylinders firstly.
Old 04-08-2009 | 04:59 PM
nismo619's Avatar
Mass air flow sensor check the wires. throttle postin sensor stuck ? check to see.. there might be a bird stuck in your air intake... lol it happened to my 1982 280zxt
Old 04-08-2009 | 05:51 PM
SpeciallySpiked's Avatar
I'm a Registered User!
I'm guessing he's carb'd and doesn't have MAF/AFM
Old 04-08-2009 | 06:11 PM
KasbeKZ's Avatar
Pr0n Addict
i want to say he did a l28et? maybe?
Old 04-08-2009 | 06:38 PM
he is running stock carbs if i remember correctly. might need to synch them and do some tunning. also check your fuel pressure and plugs/wires cap rotar. since your carb'd it should be pretty simple
Old 04-21-2009 | 07:54 AM
Fast240Z's Avatar
Well, haven't got a chance to dig into the carbs. I did replace the wires and plugs and I noticed a bit of difference, but she's still not right.
Old 04-21-2009 | 07:55 AM
Fast240Z's Avatar
Oh, build is still a l24, carbureted, pertronix ignition. Not too much more. Swapped out to an 81 ZX alternator.
Old 04-21-2009 | 10:09 AM
duowing's Avatar
NisTuner
Check for vaccuum leaks, possible contaminants clogging fuel lines?
Old 04-21-2009 | 11:43 AM
theramz's Avatar
I have a present for you...
You have symtoms of a bad vacuum advance. Could be sticky choke linkage.
Old 04-21-2009 | 06:00 PM
Fast240Z's Avatar
I know that my dizzy is on it's last leg, was told that quite a few years ago when I first got the car and was too afraid to work on it. Anyone know where to pick one up without spending $800 to get one from MSA?
As for choke linkage, the issue occurs even if I pop the hood and disable the choke by hand at the carbs.
Old 04-21-2009 | 08:50 PM
JPerkins's Avatar
you can order one from advance for about 80.00 give or take. i went ahead and swapped up to the 83 280zx dizzy and control module on my 260z, works like a charm and theres a write up around here on how to do it. its really simple and gets rid of that voltage resistor next to the coil. if i can find it again i'll post it up for ya.
Old 04-22-2009 | 06:04 AM
theramz's Avatar
Unless your dizzy has a lot of side play try picknpull and just get the vacuum advance off of any L6. Take a piece of vac line with you to test before you buy another bad one. Best is the E-12 from a '79-'81 but they can be badly worn too.
malveras
West Region
01-14-2006 01:00 PM
VegasEdge
11-25-2005 06:39 PM
81 Black L28E
05-12-2005 03:28 PM
bobnagga
07-18-2003 01:19 PM
TER
11-23-2001 01:58 AM
Quick Reply: Help my sick Z.
