JTR manual
Guest
Posts: n/a
Re: JTR manual
order from www.customconversion.com
you could also try your local TECHNICAL BOOK shop.
They probably won't stock it but might be able to source it for you
Guest
Posts: n/a
Re: JTR manual
try technical book shop, they ordered it in for me, at around $65 or so
well worth a read...
has very good install pics, everything on installing the V8...
got some good suspension stuff in there also,
and brake stuff also...
doesn't have much about chassis strengthening i dont think.. ive read it a few times, but memorys a bit off, as i'm tired..
<font color=blue>76 260z</font color=blue>
The NiteRider
The NiteRider
Re: JTR manual
depending on how much power you want to run with the v8. over 300hp, the chassis will eventually start flexing and twisting from the torque. Generally, you want to put in a rollcage, and do a search for pete paraska's v8z, and he has custom measurements for frame rail strengthening and bolt in info.
Guest
Posts: n/a
Re: JTR manual
RUNNING A MILD 350 CHEV DOES NOT REALLY REQUIRE THAT MUCH WORK APPART FROM THE BRAKE PAD UPGRADE AS THE CHASSIS IS QUITE STRONG ANYWAY.. UPGRADING THE ENGINE FROM THERE WILL DO. 260Z HAVE EVEN MORE STRENTH IN THE CHASSIS THAN A 240Z. NOT TO SURE ON YOUR REQUIREMENTS FOR LEGALLITY IN YOUR COUNTRY THOUGH. WE ARE BLESSED WITH A WELL THOUGHT OUT DESIGN.
