Question about 240 turn signal feature
Did the 240z's turn signal automatically shut off once you are finished with the turn?(in other words, it had a cog on the mechanism that trips the arm back to the neutral position). I have to manually turn my back to neutral.
The grease that lubricates the turn signal mechanism has likely attracted a ton of fuzz, lint, and crap over the years, gumming up the return feature. Remove the plastic clam shell that covers the steering collumn and clean ALL the grease and crud out of the mechanism. Then use some light weight grease to re-lubricate the mechanism. it should work now. re-Install the clam shell.
OrangeZ32
06-19-2004 03:35 PM
