rear brake pads
rear brake pads
my old ones were all worn out so i bought new rear brake pads
--the one against the cylinder fits good but the one oposite is like too big ?? what the hell
both pads are of the correct width .41 in
help any1
wooohooo done done finaly done
help any1
Guest
Posts: n/a
Re: rear brake pads
what do you mean too big? is the metal backing too large? or is the brake material too thick and wont fit in between the rotor and the outer part of the caliper?
get that piston in AS FAR AS YOU CAN. the pad will fit. force it, squeeze it, buy a brake caliper tool that fits in like a pair of brake pads and screws down pushing the piston down.
good luck
SoCalZ Prez
http://www.socalz.org
good luck
SoCalZ Prez
Guest
Posts: n/a
sorry
i was thinking front brakes.
on the rear you need to screw the caliper into the housing. screw it in alllll they way as much as you can. get a vise-grip on there. sometimes using the edge of a flathead screwdriver works just as good. screw that thing in and you should have more than enough clearance.
again, good luck
SoCalZ Prez
again, good luck
SoCalZ Prez
Re: sorry
like i said when i screw the cylinder in i can fit the pad that goes against it
but i cant fit the one across from it (the one against the caliper)
i will check the other side the one i am trying now i think is screwed up ill try the other side and if it goes in ill get new parts for the other side
Guest
Posts: n/a
LemonHead
03-21-2022 09:02 AM
nd_track_driver
02-24-2009 06:11 PM
