Remove oil cap and engine dies
Old 08-28-2005 | 02:59 PM
stemo76's Avatar
When I remove the oil filler my 76 l28 dies. Is this normal or do I have a problem. Car seems to run fine otherwise. As fine as a 30 year old neglected car should
Old 08-28-2005 | 03:42 PM
Z*Tech's Avatar
That's correct. Your engine is sealed to give a negative air pressure condition when running.
Any opening, oil filler cap, oil dipstick...will cause an error in this ventation.
Old 09-09-2005 | 08:40 PM
ricekiller1985's Avatar
that is really strange. I have never heard of that and it makes no sense to me
Old 09-11-2005 | 12:41 PM
VenomousZX's Avatar
Comeone Geoff,mine does it all the time, its a old POS with crappy fuel injection
Old 09-11-2005 | 12:44 PM
Fast240Z's Avatar
does that only happen on fuel injected motors? My carbureted L24 doesn't do that.
Old 09-14-2005 | 09:47 AM
zpeedracer25's Avatar
Only a symptom on injected cars. To put it in simpler terms...the crankcase ventilation is sucking outside air into the motor when the oil cap is opened. This outside air isn't being measured or calculated by the air flow meter, thus causing a tremendously bad reading. Its just like causing a massive vacuum leak.
jgw2205
04-03-2009 05:10 PM
mrelegal1
11-02-2005 07:30 PM
b300z
32
08-25-2004 09:28 AM
vasago
05-10-2004 04:21 AM
dhm
05-08-2003 10:07 PM
