Skyline swap?
Re: Skyline swap?
depends which skyline. engine wize, rb20det from the r32 gts-t, and the rb25det from r33-4 gts-t are almost a direct bolt in. you'd only have to procure 200zr motor mounts (that's a 300zx z31 with the rb20det motor commonly found in japan and australia), that as I understand, bolt up directly to stock mounting locations.
And if you want detailed info on RB26dett motor swap (skyline gt-r), you can find it here:
HybridZ link
Other things to include in the swap would have to be either a pressurized tank, or an external high rate electric fuel pump, custom drive shaft, custom tranny crossmember, wiring harness (you could use one out of a skyline), air/fuel and boost management, cooling system, etc
'73 240z
'99 neon R/T
HybridZ link
'73 240z
'99 neon R/T
Guest
Posts: n/a
Re: Skyline swap?
Just a clarification - the 200ZR wasn't released in Australia, neither was the 200ZX or 300ZR.
The RB motor-gearbox is about 30mm longer than the L series assembly. The biggest problem with this conversion in the USA is that the engines are not well known. Australians have been using them for conversions for 6-odd years (you don't want to know how much an R32 RB20DET was in 1993...), but we had the family from 1986 onwards. This has meant that there are a lot more people familliar with the design.
Ben
Adelaide
Sth Australia
IZCC#1902
240Z L31ETT
L28ET MR30 Skyline
FJ20ET DR30 Skyline RS-X
Ben
Adelaide
Sth Australia
IZCC#1902
240Z L31ETT
L28ET MR30 Skyline
Guest
Posts: n/a
RB conversion parts 4 sale
Hi all,
I am making modified oil sumps and oil pick ups + engine mounts etc 4 sale for RB conversions into zeds. email me at nguyenxcuong@hotmail.com IF, AND ONLY IF you are seriously interested.
Here are some links to pics of my RB26DETT 240Z:
http://www.240z.org/photopost/showphoto.php?photo=1871
http://www.240z.org/photopost/showphoto.php?photo=1872
http://www.240z.org/photopost/showphoto.php?photo=1873
http://www.240z.org/photopost/showphoto.php?photo=1874
http://www.240z.org/photopost/showphoto.php?photo=1875
http://www.240z.org/photopost/showphoto.php?photo=1876
http://www.240z.org/photopost/showphoto.php?photo=1877
http://www.240z.org/photopost/showphoto.php?photo=1878
http://www.240z.org/photopost/showphoto.php?photo=1866
http://www.240z.org/photopost/showphoto.php?photo=1865
RB26DETT '73 240Z
L26 + E88 '77 260Z
RB26DETT '73 240Z
L26 + E88 '77 260Z
george
03-14-2002 11:06 AM
