spark plug/plug wires
Old 09-24-2002 | 11:10 PM
Spudz's Avatar
Re: spark plug/plug wires
I have had the best luck running standard NGK plugs in the L motor.
Tried a few other brands , but the car just didn't run the same. My car
sits alot between events , so I try to keep fresh plugs in it.
Old 09-26-2002 | 08:58 AM
Cooler burning plugs are meant for a points distributor because a coil for a 260Z is less voltage as to not burn out the points. You won't nessisarily get more power by changing the plugs unless you put in an electroinc distributor and a hotter coil. All three units work together as a system.
Like when I changed my 620 truck to an electroinc distriubutor, I added a hotter coil but did not know to ask for a different type of spark plug. The plugs kept fouling out pretty quickly untill someone told me to use a spark plug meant for electronic igntion, not points! :-)
Old 09-26-2002 | 09:02 AM
Spudz's Avatar
Hey Bleach,
My 260 came with an electronic dizzy not a points one. I still run the
same plug in either case.
Old 09-26-2002 | 10:45 AM
Very good! Now, you can upgrade to an aftermarket coil for some added firepower.
shogunb
11-19-2012 07:18 PM
ASA240z
04-15-2012 04:17 PM
fatman
12-13-2011 11:33 PM
duowing
01-16-2009 07:40 AM
1985_mr2
11-06-2004 05:48 AM
Quick Reply: spark plug/plug wires
