starter problem
Old 04-20-2013 | 12:23 AM
albertom8819's Avatar
starter problem
the other day was trying to turn on my 280z and now the starter stay on like is getting straiht power even if i disconnect the switch... can someone please help me
Old 04-20-2013 | 07:04 AM
Steve260Z74's Avatar
Your message doesn't make much sense. I'll describe what should happen, and then you can tell us what isn't happening.
1. The starter is wired to the positive and negative to battery.
2. The solenoid is wired to the ignition key and the chassis ground.
3. When you turn the ignition switch to start, the solenoid receives power.
4. The solenoid engages the starter.
5. The starter meshes with the flywheel and turns the engine.
6. When the engine fires, you release the ignition key.
7. The ignition switch goes to the run position.
8. The solenoid is de-energized.
9. The starter disengages from the flywheel and is de-energized.
So from that description, what isn't happening?
If you need more specifics, consult the EE section of the FSM.
swapsun
04-07-2011 11:12 PM
Esc8p2NeverLand
04-11-2010 11:11 PM
Switchtr3
02-20-2010 10:38 AM
User395
02-03-2009 04:15 PM
ZDriver85
05-14-2005 01:21 AM
