Starter Relay Problem- 240z
Old 04-11-2010 | 11:11 PM
Esc8p2NeverLand's Avatar
Well I tried installing a relay for my starter today with no luck.
87: 20A fused line from (+)
85: (-)
86: ignition switch wire on solenoid
30: To signal wire (original wire that went to solenoid
I tried three different relays just in case; Ebay no name, DEI, and Bosch.
I checked voltages and was getting fine readings. I disconnected everything and reconnected the signal wire back to the solenoid to see if the starter still worked. Worked just fine.
I'm not sure if this could have anything to do with it, but I installed a new starter switch and noticed the previous owner did not connect the two wires from the switch. He just had it plugged into the socket. So I did the same.
I'm not sure if there is a reason he did that. Maybe has something to do with the electric fuel pump or Mallory ignition? No idea.
Thanks for reading!
Tyler
swapsun
04-07-2011 11:12 PM
Switchtr3
02-20-2010 10:38 AM
User395
02-03-2009 04:15 PM
AlongCamePeter
09-12-2004 07:20 PM
agent_86
06-14-2004 03:14 PM
