starting issue
Originally Posted by 280z racer
Ok the car has spark. The fuel pump was not turning on, so I ran a B+ to it and it works. But the fuel injectors are not getting a signal. Is it a relay or module? I have no clue.
Ok. I have spark and tried to start the motor and nothing. Then I found out the fuel pump was not on, so I ran a B+(power wire) to it and it turned on. So I tried to start it again and nothing then I used ether and still nothing, then I checked if the fuel injectors for power nothing, so what is it?
Do you have the Haynes manual / FSM??? It should be clearly visible in there. If not... have you seen our documents thread that has the manual in it? https://www.zdriver.com/forums/showt...974#post194974
sorry here is a direct link. but the site seems to be temp down
http://www.atlanticz.ca/index.php?op...pper&Itemid=69
Did you see this? There are tons of tests that are explained in the Haynes Manual, and in the 280z EFI Bible: http://www.atlanticz.ca/zclub/techtips/EFI&fuel.htm (bottom left of the page).
1979 280z
01-05-2015 02:58 PM
