steering wheel fitment
Old 04-15-2008 | 12:31 AM
tehweej's Avatar
what bolt pattern/style mount does a 77 280z have for a steering wheel? Im looking at getting a sparco suede wheel and am not sure if i need an adapter or what.
Old 04-15-2008 | 07:26 AM
Single nut in the middle... take a look at your stock steering wheel & you will then see.
Old 04-15-2008 | 09:44 AM
tehweej's Avatar
ok. i havent had a chance to take mine apart yet. thanks!
Old 04-15-2008 | 09:49 AM
Pull off the horn button / pad.... shouldn't take too long to do that.
Old 04-15-2008 | 11:49 PM
tehweej's Avatar
heh. happened to have a phillips with whilst waiting at a drive thru. seems simple enough. do most aftermarket steering wheels fit or do you need a hub/adapter? Ideally i would like to get a quick release as i plan to rally prep my z and getting in/out will be tight. that and you cannot have a key ignition... but hey. itll be fun!
Old 04-15-2008 | 11:55 PM
You can make most any wheel work if you have the know how. Pick out the wheel you want, and RESEARCH it.
Old 04-16-2008 | 12:01 AM
tehweej's Avatar
*sigh* fine... you are no fun...
Old 04-16-2008 | 12:03 AM
You don't find "researching parts and modifications" about your car fun? That's weird....
Old 04-16-2008 | 12:14 AM
tehweej's Avatar
i guess im just antsy and dont want to research, i want an answer now! jk. with a lil prodding from you i figured it out.
Donn144
02-12-2014 09:35 PM
mrbillishome
03-04-2010 11:04 PM
RobbyStyle
03-03-2009 07:42 AM
1tuffz
06-04-2002 08:20 AM
1tuffz
04-01-2001 01:08 AM
