Timing mark?
Timing mark?
Ok I'm trying to set the timing on my Z but theres no timing mark on the crank pulley! I've looked over the entire thing and I can not see a mark anywhere... I know where it should be but I cant see it at all.
So can someone tell me how I can find 0* TDC so I can put a mark on the pulley?
It's there... just gotta run your finger nail over the lip until you find it...
https://www.zdriver.com/forums/280zx...-timing-34078/
https://www.zdriver.com/forums/280zx...t-build-27965/
Well, you can either pull the rocker cover and line up the cam to TDC, or pull spark plug #1 & stick a pen in, and hand turn the motor until the pen doesn't move up anymore (or use a flashlight).
Or remove the crank pulley and you can find it from the crank key.
