timing probs
Re: timing probs
I'm guessing that when you replaced the head gasket that you dropped and replaced the timing chain?
So that is probably your problem. either you didnt' get the marks lined up on the chain and the sprocket or you just got the oil pump set in one tooth off.
If you have a timing light, how far off is your igntion timing? Or does it even run?
alanq64
01-27-2006 01:56 AM
Captain caveman
07-24-2005 10:49 AM
