Turbo Tranny with stock engine
I had a question for you guys. I'm looking into getting a 240z. Anyway I was wondering is it worth swapping in the T-5 with the L24? Or is it better off with the original tranny? Or if you swapped in a T-5 would you want to use a different rear diff ratio? I'm just looking for people's thoughts and experiences with doing this.
Originally Posted by duowing
If you have the the T-5 and Driveshaft on hand would it be worth it?
I personally like the T5 a lot more than the stock n/a tranny. I installed a Mustang shifter & shortened the stick (not a true "short throw" but better than the mile high stick). Mine has held up a lot better than the n/a... Didn't Bleach have a thread on "T5 experiences?" Oh yes... here it is: https://www.zdriver.com/forums/showt...highlight=borg
I think the best thing about the T5 is the lower first gear. It will help the turbo spool up faster. You will need a R200 diff or at least the pinion yoke for the earlier Zs. I have a T5 with the Mustang shifter for the L28T I'm putting together. I don't see any point in using it with a na engine but if you already have the parts, why not?
borini63
09-13-2012 12:00 PM
THE BIG ONE
05-17-2003 06:57 PM
