what are the oil cans for on top of my carbs?
Guest
Posts: n/a
whats the oil things for on my carbs? what oil should i use and what are they called technically, thanx (74 260)
AND can i buy a holley 390 and manifold and get rid of all this dual carb stuff? anyone got this setup and how does it respond for ya, and where did u get it, thanx again. (errr i know where to get the carb, just the manifold and linkage and brackets and such)<P ID="edit"><FONT class="small"><EM>Edited by turrbo on 03/07/02 09:55 PM.</EM></FONT></P>
Guest
Posts: n/a
Re: what are the oil cans for on top of my carbs?
The "oil things" on your carbs are dampers to smooth out the engine performance. The piston and spring assembly is there to prevent the air piston (the big one with the needle in it) from fluttering as the accelerator is suddenly depressed/released. The air piston has to "work" against the dampening provided by the oil moving around the damper piston inside the small "depression chamber".
The Haynes manual suggests using SAE 20 engine oil in the dampers, but any good light oil will do. You might surf around the various Z-car web sites for more info. Owner recommendations vary widely - I've even seen posts from folks who used transmision fluid. A heavier oil will increase the damping effect.
Guest
Posts: n/a
yeah she gave me a quart of 20 wt and filled em when i bought it, ok thanx funny story too, she said she had her oil changed at a quick lube place once, and they filled those with 10-30 hehe (she made them drain , flush and refill with 20 wt hehehhe)
Guest
Posts: n/a
If you want to be a purist about filling, there is a "full mark" on the shaft above the oil piston. I just fill mine until the oil is at, or oveflowing, the top when the piston is inserted. Too much oil is not a problem, too little is.
Guest
Posts: n/a
Holley carbs on a z?! WHAT?! lol i'm sorry I just really don't like that set up. But if you want to burn some money on that set up. You can get the 4 barrel manifold from MSA. www.zcarparts.com i think its like 400 bucks or something like that, and they ofcourse you gotta get a holley.
Why do that when you can get nice redone SU's? and best of all tune them yourself. Check out www.ztherapy.com
don't tell me those don't look nice, and they run great on inline 6's. if your 74 260Z is stop you must have the SMOG flattop carbs which are a pain. I would seriously consider SU's non smog type before you invest in holleys. I had a friend make that mistake.
zya!
Yuichi
<a href=http://strictlyz.com>StrictlyZ Store<a>
<a href=https://www.zdriver.com>ZDriver.com<a>
<a href=http://sportzmagazine.com>Sport Z Magazine<a>
-Have you had your daily dose of Vitamin Z?-
zya!
Yuichi
Guest
Posts: n/a
actually my carbs are fine, i just thought a single 4 barrel would really free up ALOT of clutter under the hood and make it so much easier to work on. i wasnt referring to dual 4 barrels, that would solve nothing.
