When It rains it pours
Old 02-26-2007 | 09:12 AM
skittle's Avatar
Taste My Rainbow
New update on the Saga Of "Terror Z"
Got my headlights fixed temporarily. We routed the hot wire and ground from the side markers. T/S the problem to wiring in the harness some where near the front.
As soon as one thing gets fixed so I can start driving every day some thing else happens. When I went over to the guys house I got cut off in traffic and had to slam on the brakes. In doing so my fan went into my radiator causing a small hole in the top of the rad. Put barks sealer in it and started driving again. The hole filled up fine but the fan kept getting stuck under the top of the rad.
Long story short I had to cut part of thte plasitc blade with a pair of dykes to limp her home.
So Link gods is there a link on how to make a zx rad fit into a z rad?
Old 02-26-2007 | 09:21 AM
Dude no!!!! I know how ya feel.
The S30 & S130 rads should be almost the same no?
Old 02-26-2007 | 09:29 AM
skittle's Avatar
Taste My Rainbow
no idea man, i sure hope so. saves money and time.. lol i'll be swapping engins and trannys in the next month or so. from a N/A 4-speed to a N/A 5-speed. on that note will I have to swap out ecus as well??? just thought of that...hmmmm
Old 02-26-2007 | 01:58 PM
I did that. Put a ZX rad into a 1975 Z
The top two bolts that hold the radiator in line up. The bottom two do not. The ZX rad will hang a good inch lower than the S30 rad did. It clears the ground fine, but if you look under the car from the front, the radiator is the lowest point... hmmmm....
...I sold the car
oh, and how did your fan suddenly hit the radiator?? Rad not bolted in, or did your engine just shift forward?
Old 02-26-2007 | 02:46 PM
skittle's Avatar
Taste My Rainbow
I think it was a combination of both.. time to get a electric fan me thinks.
Old 02-26-2007 | 05:02 PM
Coolie's Avatar
Was it the shroud or the radiator that it hit? Have you checked the engine mounts?
Most people I know remove the shroud in the S30's
Old 02-26-2007 | 05:53 PM
skittle's Avatar
Taste My Rainbow
No Shroud, Think The Engine Mounts Are Going Bad... Thats Ok Though I Have A Spare Set Of Brand New Ones Waiting To Get Swapped In With Some Other Stuff
Old 02-26-2007 | 05:57 PM
i dont think engine mounts would let an engind slide that much forward... i meant.. its still attatched to the tranny also... soo... i have a feeling the fan mighta flexed cause the radiator wouldnt move backwards from slamming the brakes... ever hear of the P-factor or gyroscopic procession...
Old 02-26-2007 | 06:13 PM
skittle's Avatar
Taste My Rainbow
Yeah Not Really Sure... I Think One Of The Blades Was Bent A Little Bit.
Old 02-26-2007 | 06:23 PM
well i mean think about it... your braking... the radiator would move away... the car... 2 metal engine mounts attathed to teh tranny attatched to the crossmember.. you might get it to rock a little bit.. but its not moving forward... i think the problem is elseware
Old 02-26-2007 | 06:48 PM
skittle's Avatar
Taste My Rainbow
The Rad Fell Foward I Looked At It Closer And 2 Bolts Are Missing At The Top. The Two Missing Bolts Are Sheard Off Parts Of Them Are Still In The Nut Plate. My Guess They Are Not The Original Bolts... Hmmm
Old 02-26-2007 | 08:10 PM
it probably didnt happen during the breaking sequence then.. maybe teh recoil once at a stop though.... that coulda tossed tha rad a lil back. well... secure your damn radiator! lol
Old 02-26-2007 | 08:52 PM
skittle's Avatar
Taste My Rainbow
I'm Going To Swap In My Zx One Its A 3 Core...
Old 02-26-2007 | 08:57 PM
its what ima gonna do to.
Old 02-27-2007 | 12:14 AM
skittle's Avatar
Taste My Rainbow
oh and an electric fan...
Old 02-27-2007 | 12:17 AM
not gonna do that ^^^
not yet at least.
z-hag
10-11-2006 12:00 PM
