1980 280ZX Removal of stereo Help!!!
Old 01-18-2006 | 07:41 PM
nismo619's Avatar
what type of tools are u using ? sounds like u might need and ADJ open end wrench ? let me know
Old 01-18-2006 | 08:20 PM
you need to remove the bottom lil covers at the carpet level (use a phillips screwdriver) to uncover the lower 10mm bolts (2 on each side). You also need to remove the knee panels drivers & pass side (they have the white light on them). You will then see 2 more 10mm bolts on each side... remove all the 10mm's and you should be good to remove it. There might be several other bolts / connections... but you will see when you get the 10's out.
Old 01-19-2006 | 03:34 PM
tougez's Avatar
Did you buy a new mounting kit for the stereo or are you going to make your own. Its really easy and cheeper to make your own as long as you don't want to ever put the original back in.
SurgeNJ
04-16-2010 03:38 PM
Casas4
06-21-2008 06:54 PM
SurgeNJ
07-19-2006 05:14 PM
wanta280zx
05-22-2006 09:07 AM
JBenbenek
10-23-2005 02:17 AM
