Hazard Switch Delima
Old 12-31-2008 | 08:55 AM
280zx2by2's Avatar
Haterade by da gallon!
<a href="http://s286.photobucket.com/albums/ll89/280zx2by2/?action=view&current=DSCN0245.jpg" target="_blank"><img src="http://i286.photobucket.com/albums/ll89/280zx2by2/DSCN0245.jpg" border="0" alt="Photobucket"></a>
got a hazard light switch from a 79 that has 5 green wires, problem is my 81 has 4 green wires, a blue and a red...
79 wire colors
-solid green
-green w/ white stripe
-green w/black stripe
-green w/yellow stripe
-green w/ red stripe
81 wire colors
-red w/ white stripe
-solid blue
-2 solid green wires
-green w/red stripe
-green w/ yellow stripe
i need the harness from the 79 (as mine was missing) is this still plug and play or what?
BTW HAPPY NEW YEARS EVE!!!!!!!!!!
Old 12-31-2008 | 08:59 AM
Is the plug different as well?
Old 12-31-2008 | 09:02 AM
280zx2by2's Avatar
no i think the plug is the same just dif wires going into it, dont know if i should try to just plug it in as there might be an explosion, or just some smoke...
Old 12-31-2008 | 09:28 AM
280zx2by2's Avatar
i just went through my FSM wireing diagram, the cooling fan is connected to the hazard light switch, why?
it does explain why when i removed an alarm system that was connected to my hazards my fan quit working
Old 12-31-2008 | 09:38 AM
The cooling fan? As in the injector / manifold fan?
Maybe Nissan thought it would be bad to have the fan come on if you are stranded...
Old 12-31-2008 | 09:45 AM
280zx2by2's Avatar
what i was thinking, like if you were over heating
well i went out and pluged it in, it works, but only when the power is on, the odd wire out is a red w/ white stripe (power wire mabe?)
do 79 hazards work w/o the power on?
Old 12-31-2008 | 12:41 PM
280zx2by2's Avatar
CAN SOME ONE GO OUT...
to their 280zx and turn on the hazard lights w/o the key in
when you come back can you answer me this riddle,
when you turn on you hazard light switch, does the car turn on? exaple: fuel pump turns on, and you can use power windows...
like if you turned the key past acc. into the ON position...
i have checking both of my parents fords and the only thing that comes on when the hazard light switch is on, is the blinkers....
Old 12-31-2008 | 12:45 PM
I would... but I'm at work... and my Z is buried in the back of my garage somewhere....
Old 12-31-2008 | 12:50 PM
280zx2by2's Avatar
damn you and your cheap geo driving *** lol
Old 12-31-2008 | 01:29 PM
SpeciallySpiked's Avatar
I'm a Registered User!
the fuel pump and stuff don't come on with the hazards
Old 12-31-2008 | 02:01 PM
Why post a new thread? Just hijack someone else's 10th anniversary thread with your question.
Old 12-31-2008 | 02:19 PM
280zx2by2's Avatar
thank you SpeciallySpiked, i got tired of bleach not doing a simple task for me, so i realized that it wouldnt be safe for them to have the fuel pump running while your cars sitting on the side of the road so i got to looking and found a hole bunch of connectors linking all kinds of crap, disconnected them pluged in my switch and every thing worked
thank you again...
Old 12-31-2008 | 02:20 PM
280zx2by2's Avatar
that thread dont have no point anyways so i got all up in it and hijacked it!!!!
Old 12-31-2008 | 04:29 PM
Doing a simple task? I was at work. You are 3 hours ahead of us. I just got home, fooz!
Old 12-31-2008 | 07:18 PM
280zx2by2's Avatar
oh well, thanks for going to work?... and have a happy new year
Old 12-31-2008 | 09:16 PM
Right on. You and those gaters have a happy new years too
WanganDevilZ
07-30-2012 10:18 PM
boosalmi
12-06-2011 06:55 PM
ZCHondaCRX91
03-22-2011 05:35 PM
xtreme 2
12-20-2006 02:46 PM
CrazyLotusTT
12-17-2002 02:34 PM
Quick Reply: Hazard Switch Delima
