How do I Remove Illumination and Rear wiper Control from Dash.
Old 11-19-2011 | 06:04 PM
Photoguy360's Avatar
I am Changing Complete Dash but only need help with the two modules.
I've tried Many things on the junkyard dashes Illumination control because mine was in better condition. I've researched a lot to no avail. Xeon FSM for the 83 will not download.
Anyone have any hints to remove these two modules without messing up the dash.
Thanks
Old 11-19-2011 | 07:34 PM
henrycas's Avatar
pushes the button first and then turn it (left or right can not remember) then the button will come out. then unscrew the plastic nuts that hold the controls, and that's all.
good luck.
Old 11-19-2011 | 08:15 PM
Rear Wiper
Thanks, the rear wiper was pushed in then a Counter clock wise turn, the other one is more difficult. I'll post if I get it out- right now my Garage is about 40 degrees F.
Ok It's out- I had to re-screw down the front black ring then it also came out Counter clock wise.
Last edited by Photoguy360; 11-19-2011 at 08:24 PM. Reason: Illumination control out.
Old 11-21-2011 | 03:22 PM
It's just a nut on the front of the control just like a toggle switch, etc. Unscrew it like you would any other nut - counter clockwise.
redman2k8
05-03-2013 12:19 PM
Mylorddragon
02-07-2013 10:11 AM
17-0/z31
01-16-2012 01:06 PM
mooredb
06-27-2010 05:59 AM
Comrade_Charlie
09-07-2006 05:51 PM
