interior accessory light question
hi i just picked up a 1983 280zx na 2+2 and im wondering, you know the air conditioner/heater unit, do the letters light up? because i cant see what it says at night. oh and the tripometer lights up but it doesnt really say anything. im not ultra concerned about it not working but it would be kinda cool to make it work. does it only turn on when the cars moving? (and yes it does at least light up.)
Welcome to ZDriver!
The a/c & heater face does light up... if it's not (and the rest of the dash lights up) then the bulb it burnt. It's 90% easy. That is: remove the vent trim that surrounds the a/c controls (should be 2 screws by the radio & 3 screws above the a/c controls). Once that is out of the way, you will need to remove the a/c controls face (8mm bolt on the right, left, and top... which is the 10% not so easy part). Once removed... replace the bulb.
As for the tripometer... what do you mean "it doesnt really say anything" ? As in it doesn't keep track of the miles?
thanks for the bulb info!
yes the tripometer doesnt display any numbers at all.
oh i just noticed another thing (yes im pullin an all nighter
i turned on the radio and it sounds like theres a blown speaker inside the center of the dash...is it replacable with newer speakers? and how do i get to that thing? im going to be getting a shop manual tomorrow so that should help....yes its the real deal, not a haynes
Originally Posted by WildmaN
You are going to have a blast getting the center dash speaker out, and replaced. I already went through that nightmare.
On another note, my aftermarket CD player required 2+2+2, and the 1 front speaker combined with my 4 rear speakers fried the head unit, cuz it was 1+2+2 - got a replacement stereo under warranty because the instructions didn't specify the consequences of 1+2+2.
Jade's dash was already blemished beyond repair (cracks in about 4 areas along the gauge areas), so I just cut a whole in the top of the dash, ripped out that 1 speaker, then installed a dash cap to cover the hole, which is perforated (still appears to have a speaker there), and used external tweeters to make up for the other "2" to equal out the 2+2+2.
Yeah the easyest, well only way to replace these speakers is to remove the dash. But i would remember where all the vacuum lines go, this is why i don't have a heater anymore. Anyways, your not alone, i just blew all my speakers after up grading the head unit. Well good luck.
Just unplug it if you want the fartin to stop, or just follow these instructions to remove the dash...http://www.atlanticz.ca/zclub/techti...sion/part1.pdf . It'll be easier in the long run...
joel280zt
08-02-2012 06:10 AM
