View Poll Results: Take another 1/2 inch off?
Yes
50.00%
No
50.00%
Voters: 6. You may not vote on this poll
My Shifter Mod, N/A Trans
Old 03-05-2009 | 05:30 PM
FubarI33t's Avatar
Well I wanted a short shifter for my Z. but could not go T-5. So i got my hands on a few S30 shifters, and cut/grinded one down. So here it is. I am thinking of going down a lil more.
Old 03-05-2009 | 08:00 PM
You have a BOV for a shifter!
Old 03-05-2009 | 08:27 PM
FubarI33t's Avatar
That is a 6$ Simulated Pistion Shift ***! and i had to replace my old shift ***. i kinda forgot to take shifter out on engine pull. i was tired. and it was late. So. after ripping out the insulator boot( Now everything is loud ) the red acordin boot. and my 30$ shift ***. i had to replace it. and decided to shortin it a bit while i was at it
Old 03-08-2009 | 12:19 PM
pete8717's Avatar
How much did you actually cut out of it? When I did that to my shifter I took out an 1 1/2" and I like where it is right now. Any lower wouldn't feel right in my opinion.
Old 03-08-2009 | 05:40 PM
FubarI33t's Avatar
2 1/2 inches. I love my shifters really low.
Old 03-10-2009 | 09:48 PM
straight hate's Avatar
I wouldnt take any more off. You didnt even have to take any material off. you just Dog leg it like I was saying in your other post. Heat it about an inch above the hole, put it in a vice and bend it back. Cool it. Heat another inch and a 1/2 above your first bend and push it forward. Short throw, specially' with all the material you already removed, that thing would be SCCA ready. I'll pull my shifter out this weekend and put it next to a stock unit and show you guys what I'm talking about. Nobodys heard of doing a short throw like this?? This cat I used to work for auto crossed Z cars in the late 70's and said he did it all the time. It works.
Old 03-10-2009 | 10:01 PM
Are you saying to make it look like this?
That's not making the throw any shorter, just moving the position. The "technical" way to make a shorter throw is to lengthen the bottom pivot (like a lever in physics).
Old 03-10-2009 | 10:11 PM
Thats the bend I was talking about. The old timer I worked with used the 240/280 style shifters and I think he shortened them too. I didnt shorten mine, just bent it, and flipped the plastic piece(82') upside down, lengthing the bottom pivot. Does that count? Or is it just a mind fuct, it feels shorter.
Old 03-10-2009 | 10:14 PM
Ah roger... yeah, I didn't get that you lengthened it in your first post. Indeed... shorter throw.
Old 03-10-2009 | 10:20 PM
So, for anyone doing a search, this might be of some use. After you dog leg the shifter you must flip that platic piece around to lengthen that bottom pivot point... Creating a short throw shifter. Then shorten it to desired length. Do I have that right Nismo?
CrazyLotusTT
11-17-2015 08:45 AM
joselitopr
10-20-2014 08:35 PM
7d82adz
05-13-2014 05:40 AM
bluesman1958
05-03-2004 09:25 PM
dhizzy
08-02-2002 10:51 AM
