Pantera Deck
A pantera deck is this cool looking thing right here... http://www.arizonazcar.com/decks.html I was going to buy one but apperantly they dont fit on the 2+2 (Son of a B****!).
Originally Posted by BleachZee
Does it even fit a 280ZX or just a Z? The picture only shows the older body style.
Well I have seen pictures of the deck with pins holding it down and I have see pictures of the deck with no visible pins so I am not sure if you can use stock hinges and latch or if it will even lock at all.
Originally Posted by Heat Rave R
It looks pretty sweet, but it sounds like it has to be molded into the existing rear hatch and then a custom rear window fabbed up. It sounds awful expensive to do if that's how it's done.
Originally Posted by fenderbender02
I see what you are saying now! I am such an idiot! You take the glass out and the deck goes in the hole, now it all makes sense. Well that is going to be much easier than I thought. Thanks Heat Rave R and that is a bright Prelude you've got.
Well the fiberglass won't be a problem the only thing I think can pose a problem is finding a hatch with no rust(ha!) or buying a new one. Or buying a fiberglass hatch and the pantera deck mold them together then install them on the car (and that would cost almost as much as the car did.). If I decide to do this I will definetly post before and after pics.
Black260z
03-16-2013 01:52 AM
