Set the digital clock in 280zx
Guest
Posts: n/a
This is probabally a really dumb question, but for some reason, I cannot figure out how to set the clock in my 81 280zx. I have tried the little button on top, and the turn stick at the bottom, but it never accepts the time I set. PLeeeeease help me. I am also having some complication witht the cruise controll. Is the little button on the end of the blinker stick used for the cuise controll, and if not, what the heck is it for. PLease reply, or feel free to contact me directly. Vorhese234@earthlkink.net - vorhese234 on a.i.m. Thank you.
I'm with you guys. Usually I can figure out how to set those Digital Clocks on cars, but the 280ZX clock confuses and astounds me. I cannot figure out how to set it. As for the cruise control, I believe that button is what you hit to set your speed. You probably need to fix your cruise control thing. I know I need to fix my sensor or whatever. If anyone can give me any information on that, it'd be appreciated. I heard something about using a screw or nut or something in place of the rubber stopper? I don't know where this is though.
Your Jumping Speedo Is A Major Problem With Cruise. It Will Not Register A Steady Speed At The Sensor Therefore Not Giving You Cruise. To Fix The Speedo You Might Need To Lube The Cable With Some Light Oil Or Grease, If That Doesnt Work Then You May Have To Replace The Gear Inside The Tranny With The Same Corrosponding Color As Removed. The Button On The End Is Indeed How You Set The Cruise
