Aftermarket wheel offset questions...
Old 08-22-2011 | 02:46 PM
darkbuddha's Avatar
Is there a thread for different wheel/tire combos and offsets folks are using? If there is, I couldn't find it, but I had a question...
My brother has offered me the Kosei K1s off his old S13 240SX drift car for cheap ($200 for wheels with decent 225/50/15 tires). The wheels are 15x7 with a +35mm offset. From my research here, it sounds like I'll need a set of 1.5" wheel adaptors to make the wheels fit. Is that correct?
Old 08-22-2011 | 05:51 PM
Matt K's Avatar
Yes, you want your effective offset to be close to zero with a 7-8" wide wheel. Negative offset with wider or if you wanted the flared look.
Old 08-23-2011 | 06:01 AM
darkbuddha's Avatar
Hmmm...I'm a little confused. Based on my experience fitting wheels on other cars, zero offset on a 7" wide wheel should yield an effective backspacing of ~4.125", and zero offset on an 8" wide wheel should yield an effective backspacing of 4.75". That's over 1/2" (~13mm) of difference in available backspacing. If that's true, I should be able to get away with using a 1" adapter instead (which are bit less expensive than the 1.5" adapters).
Looks like I'll need to get under there and do a bit of measuring to be sure.
Old 08-23-2011 | 04:32 PM
The ZX is a little different than most front wheel drive cars and most modern cars with their +35 offsets. The S130 is pretty close to 0. I'm running -19 on 9.5" wheels
SilverSurfer
06-30-2015 05:39 PM
Darkmann
35
01-25-2008 10:15 AM
FREE Z
04-11-2007 08:46 AM
Spartacus3006
04-09-2002 12:16 PM
jav
08-13-2001 11:33 AM
