brake lines
Old 10-18-2006 | 10:51 AM
chinesekid's Avatar
brake lines
i got stanless steel brake lines.. but i cant get the old one off... dont know why but... i got the hard line off but i cant get the old line off the frame.. any ideas?
Old 10-18-2006 | 11:21 AM
You talking about the brackets that hold the lines onto the frame? Each one should have a 10mm screw on it. If they are rusted, apply some PB Blaster & let it sit for 5-10 min.
Old 10-18-2006 | 01:42 PM
if that's not it, then notice the clip on the underside of the flange that holds the end of the brake line. Slip that clip out with a flathead screwdriver.
Old 10-18-2006 | 05:28 PM
nismo619's Avatar
u will need a 10mm open end wrench get a good pair of vise grip trust me ! 17 mm 14mm wrenches... pb blaster woorks great and u will need the best item " needle nose pliars " to pull off the " clips " that hold the hoses to the frame.. your clips might be heavyly incrusted with mud.. etc.. clean up the area ! i had do put on stainless lines on my 82 turbo the pain in the *** line is the right rear inner line like OH MY GOD ! pain in the *** !
Old 10-18-2006 | 07:58 PM
chinesekid's Avatar
got it out.. it was just rusted out that took alot of force to get it loose...
Speed
10-09-2009 06:32 AM
Duck Ryder
06-23-2008 04:02 AM
duckyz
11-29-2004 07:06 PM
lil_racer_tony
08-27-2002 06:59 AM
Quick Reply: brake lines
