front end bushings
Old 11-06-2003 | 07:40 PM
Z Car Barbie's Avatar
User Friendly
I would definitely recommend the urethane bushings. Absolutely.
Old 11-07-2003 | 06:21 AM
Jimmys83Z's Avatar
I would also go urethane as well cost alittle more but will out last the rubber ones by years. If you install them yourself its not to bad just a bitch to get them to compress to get nuts and bolts started.Good luck..................
Jimmys83zxt
Old 11-07-2003 | 09:56 AM
I have urethane bushings on the front sway bar and that' what causes the squeaking! The two bushings that hold the sway bar to the frame of the car are the cause. When the front of the car goes up and down on both sides the sway bar twists in those bushings. You're supposed to buy some special urethane lubrication but I put them in dry... now I know.
Old 11-08-2003 | 04:35 PM
Jimmys83Z's Avatar
www.victoriabritish.com they have whole kits, you will have to order catalog............
Jimmys83ZXT
Old 11-10-2003 | 03:33 PM
icice9's Avatar
Super Siver & Black Stud
i just installed my bushings this weekend and yeah... big improvement.. i went with energy suspension bushings.. the hardest one to put in is the lower control arm bushings... you gotta either press out the metal sleave or use a hacksaw and cut it out.. i pretty much changed all my front suspension parts... new ball join, tie rods. end linkage bushings and control arm bushings... but i did notice that i need to change my idle arm assembly.. thats the next part to work on in a couple of weeks.. but yeah.. go with urethane bushings.. theyle last you a lot longer too...
Old 11-11-2003 | 10:24 AM
Idler arm? I thought those were only on manual steering systems with a gearbox on one side. Don't you have power steering in your Z or a rack n pinion?!? ...or am I just uneducated?
Old 11-11-2003 | 10:54 AM
icice9's Avatar
ive got the the power assisted recipricating ball steering... wish i had the rack and pinion... im planning on swapping it out but it looks like that wont be for a while.. but my right idler arm is pretty worn out.. but it dosent look too hard to change..
duckyz
12-05-2004 07:24 PM
kivadog
02-27-2004 11:06 AM
benz333
07-26-2003 08:14 PM
zpeedracer25
04-08-2003 03:38 PM
Sordith
05-28-2001 12:00 AM
