Front Strut Installation!
Hey guys, whats the easiest way to put on the new struts and springs on the front. I bought new ball joints and tie rods, but the whole strut and spring assembly is being a dirty biznotch.
Thanks
bob
Thanks
bob
From my post this morning in Skittle's thread: https://www.zdriver.com/forums/280zx-s130-forums-77/front-shocks-19826/
Once the strut is out, just use a spring compressor to remove & install new springs.
They are STRUTS, and there are shock cartridges inside. You have to take off the steering rack ends (usually you need a ball-joint removing fork), unbolt the strut from the control arm @ the ball joint (those are a biotch & usually require a breaker bar), and take off the 3 nuts on the top of the strut tower.
Thanks Nismo. I might have frazed my question wrong. I have the new struts, and springs already put in, i am having trouble getting the entire assembly to mount right on the ball joint. The left front strut and everything is bolted in, but i cant get it right on the ball joint.
Any Ideas?
Hope this clears up the question.
bob
Any Ideas?
bob
ball joint removal
you do not have to take the strut off just undo the tie rod off the steering rack mark the rack at where the nut screws out then use a tie rod removal tool first undo the nut at the bottom of the ball joint.
What? in my world we just undo the two bolts that hold the steering arm onto the strut housing, no special tools involved. I hate pickle forks, they tear up balljoint boots and tierod boots. The press type tools are nice, but one baby sledge in your toolbox replaces all of those things. Just smack the crap out of the knuckle a few times and magically everything comes undone.
KevinH
17
10-25-2005 06:40 AM
KevinH
16
09-28-2005 01:53 PM
Yuichi
05-12-2002 09:04 AM
