I Need Help!!! Please Post
Guest
Posts: n/a
I have a 1982 280zx turbo 2+2 and it pulls to the right, it pulls to the right a lot more when you brake and i was wondering if anyone had encountered this. I was told the brake line could not be draining the pressure and keeping the pad on the rotor so please tell me whats going on.
Your solution might be the correct one but first you need to do an inspection. Take both front wheels off at the same time (support the car n jackstands) and compare both brakes. Check the condition of the calipers and look for any worn parts. When I bought my 79, the owner did a brake job on one side only. needless to say, it didn't stop evenly. Check to see if the brake is dragging. turn the brake rotor by hand and it should take minimal effort; a little is okay but not excessive. Use your own best judgement. Both my calipers were frozen from rust, It only cost $90 for fully loaded left and right calipers from Autozone.
Last solution, Master sylinder isn't supplying equal pressures. This is the last resort but I would check the others first.
Brian
Brian
The rear brake cables on the 280zx are known for seizing up or getting sticky. Mine did that on the right side only, and for now I just disconnected it.
The other solution is to sell me your car cheap and I'll fix it.
