MAster Cylinder
Old 03-26-2012 | 11:50 PM
jurickwessels's Avatar
Exclamation MAster Cylinder
Hi guys,
This morning i realised that my brake pedal can go more down than usual so i think its the master cylinder that need to be replaced. I have a '83 280zx, is it possible to use a modern master cylinder or do i have to order the original ?
thanks
Old 03-27-2012 | 06:16 AM
jaromgi's Avatar
It might just be a small be leak somewhere in the line. I'd hate for you to have to replace something you don't need to.
Old 03-27-2012 | 07:17 AM
^^^ Indeed... check everything before ordering random parts. Check the inside firewall below the master cylinder plunger for fluid (pretty common when the master starts leaking). Also check the slave. If no leaks, flush system and fully bleed.
Bravenewme
08-22-2014 05:51 PM
98blackbell
08-01-2013 01:36 AM
burble_boy
12-19-2012 05:53 PM
dault
07-07-2007 10:11 PM
tsefreeflow
09-30-2004 01:54 PM
Quick Reply: MAster Cylinder
