Max front tire size
Old 07-15-2009 | 10:20 PM
bojo68's Avatar
Max front tire size
I've got a project goin on, and I'm liable to end up with some 19" wheels about 8-8.5 wide that are more or less surplus. Question is on a 19" rim what can I get bye with for large tire size, and please, skip all the debate about offset.(it's adjustable) Just trying to give the thing a chance of cornering like like it will accelerate..
Old 07-16-2009 | 08:56 AM
Have you tried a tire size calculator? 19" is going to push you into the "oversize" category with tires unless someone makes a 30 or 25 sidewall series tire.
http://www.miata.net/garage/tirecalc.html
Stock tire size is 205/60-15. You can fit a 245 width in front. That's about max with the correct offset.
245/30-19 would be about right, if that size of tire is even made.
Old 07-16-2009 | 09:40 AM
bojo68's Avatar
Doesn't look like many have messed with 19" fronts, and the more I think about it, the less I like the idea.(would have to look, and be stupid) How about this, what's the biggest tire the stock 14" wheels(or maybe the z31 15x7"s) will tolerate?
Old 07-16-2009 | 12:22 PM
what do you mean by big? Are you going for the widest tread possible? Wide tread will be the same max no matter how much wheel diameter you have.
Old 07-16-2009 | 12:31 PM
bojo68's Avatar
By big I mean the tallest and widest I can get in there without modification,(or interference) got a feeling the back is going to require all that I want to mess with on that score!
Old 07-16-2009 | 12:40 PM
Going taller than stock will look stupid and throw off your speedometer reading.
Stick with 245 in front and use the calculator to figure out the proper size. Go slightly smaller diameter if you must.
The rear can hold a really wide tire. I'm not sure how wide though.
Old 07-16-2009 | 12:56 PM
bojo68's Avatar
?? Not sure which end your talking about?? The subject is the front. Haven't had it apart, but I believe the speedo is driven off the driveline, so front tire size should not affect that. I thought only VW's drove speedo off front. Far as the back goes, the only way I know to put any power to the ground is with a big tire, and the back tire has already been selected, it's 29"x12.5".(yes, it WILL fit, only question is how much time it will take to make it) I doubt seriously anything that will fit on the front will be that big.
What I was trying to find is people that had experienced just what exactly what to big was.
Gingie
02-02-2014 02:04 PM
malibud
10-09-2012 02:27 PM
BigRich
07-19-2007 03:33 PM
Fast240Z
06-01-2005 12:58 PM
Lazerus
15
11-06-2003 11:35 AM
Quick Reply: Max front tire size
