No brakes
Old 07-18-2006 | 12:55 PM
skittle's Avatar
Taste My Rainbow
No brakes
Well as some of you may know my booster pump went out. I swapped it with a good one. Now when IU try to bleed the brakes I get no pressure. We tried to bleed them for a good 20mins or so and I was not getting any fluid from the spigets. Any Ideas on what the issue is?
Old 07-18-2006 | 01:22 PM
Have you bled all 4 corners AND the master cylinder?
Old 07-18-2006 | 01:41 PM
skittle's Avatar
Taste My Rainbow
hmmm forgot about the master cylinder... doh...
Old 07-18-2006 | 07:59 PM
EatmyDust's Avatar
com on now just wipe that mud away.
Old 07-18-2006 | 08:07 PM
skittle's Avatar
Taste My Rainbow
IF IT WERE ONLY MUD... hOW I HATE THE BRAKE SYSTEM...
Old 07-18-2006 | 08:28 PM
Brake systems are simple! Especially the Z's! Did ya bleed the master cyl?
Old 07-18-2006 | 08:39 PM
skittle's Avatar
Taste My Rainbow
nope forogt about that simple mistake... have to take off the heat shield. I had to quit after awhile its been getting in the 110+ here. I need a heat shield..
Old 07-18-2006 | 11:23 PM
skittle's Avatar
Taste My Rainbow
ok new issue... I try to bleed the master cylinder but the front one wont squirt out any fluid. The back one shoots out fine with no air... ideas??
Old 07-19-2006 | 10:01 AM
more fluid... keep bleeding.
Old 07-19-2006 | 10:20 AM
bench bleed it. Take it out of the car, stick it in a vice, push a dowel into it to get the piston to go in far enough to bleed all the air out. Run lines out of the bleeder screws on the side back into the resivours. Keep pumping it with the dowel untill only fluid goes through.
Get those bleeders tightened up and install it in the car again. Connect the brake lines to the bottom one at a time without losing any fluid if at all possible. Then bleed the rest of the brakes as normal but don't let the resivour run dry!
Old 07-19-2006 | 12:04 PM
skittle's Avatar
Taste My Rainbow
never thought of that...
Old 07-19-2006 | 12:17 PM
RodMoyes's Avatar
Doesn't post much...
Bleach is now an expert when it comes to bleeding brakes...
https://www.zdriver.com/forums/showt...leeding+brakes
Rod.
Old 07-19-2006 | 12:59 PM
Rod.
Gravity bleeding does not work!!! LOL
Old 07-19-2006 | 01:47 PM
skittle's Avatar
Taste My Rainbow
yeah thats the first thing i tried, my car sits on a hill.... I'm still having stupid trouble with it.... lol I might have to take it to a place and have them force bleed it.
Old 07-20-2006 | 01:18 AM
skittle's Avatar
Taste My Rainbow
all right got it fixed finally.... now i need another boost pump for my yellow one... more to come on that.
Old 07-22-2006 | 09:52 PM
EatmyDust's Avatar
actually gravity bleeding dose work, I did it on a small ud cab over in the shop I work at after replacing the master cylender, and everything went smoother than gravy. took me only a matter of minutes.
ddatsun
22
11-09-2007 08:47 AM
Smittyz33
03-21-2006 11:33 AM
Fast240Z
Other Cars
12-01-2005 12:35 PM
S1j9m85
05-15-2004 10:48 AM
Al Dukes
10-11-2003 01:23 PM
Quick Reply: No brakes
