Power steering leaking bad?????????
My power steering has been leaking since i bought my z 4 years ago. I haven't had the money to fix it but it just recently started getting worse, so I jacked it up to see where it was leaking an it is in the steering box where the lower joint of the steering arm screws into it. I was wondering if you can just replace the seals yourself or if you just have to buy a new part?
You have the rack in pinion power assist steering. I have heard that you can replace the seals in the rack. (or swap in a used rack) I have never done this.
Are you sure its not leaking from the pressure hose connected near the point that you described? That is the common part that leaks.
280zx power steering leaking
Saludos Gustavo
rack n pinion
I have an 82 and have the same problem I am gonna replace the whole rack however to do it you either have to take half the under carage apart or pull the motor up a little. As far as the seals go I could not find a local place that carried a rebuild kit. A new rack runs about 175$ good luck
Thanks for the information and help i'm problay going to have to take it somewhere to get it done because i don't have the time that is needed, and its my every day driving car, so thanks for everything
shall345
01-04-2004 03:10 PM
