Springs/Struts suggestions?
if you want to keep your ride height and have a stiffer ride.. i would just change your struts.. KYBs are good.. but if you want both springs and struts.. you cant go wrong with Tokicos.. if you go with the Tokicos your call will drop about an inch and a half... and youll notice a big improvement on your ride... i know i did..
After putting lowered heavy duty king springs in my 82zx im swapping over to stock height kings. Ive had nothing but troubles ever since i lowered it. most of these problems are fixable with $$ except for the unpracticle ride height unless you live in a bitumend desert. The worst has been the cv knock in the *** end. they dont like the new angle caused by lowering, they knock loudly whenever you accelerate. Just remember if your going to lower think about camber and castor correction that you will HAVE to revise. unless you want your zed to ride even worse than before when it was stock, especially at high speeds.
budmann
02-19-2007 07:57 PM
WildmaN
28
11-25-2006 01:39 PM
