Would old Z rear suspension improve ZX?
I'm working on a 81 280 ZX and making a lot of changes anyway so I was wondering about the rear suspension. The angle the rear arms swing seeams bad to me in changing caster, camber and alingment as it moves.
First, is this something that anyone notices between Z's and ZX's?
Second, has anyone ever put a Z type independent suspension on a ZX?
I know I can buy adjustable rear parts for a Z but I don't know if I'd just be wasting time and $.
people have noticed and thought of it before
Same semi-trailing a-arm setup is used in the Z31
Slot the rear crossmember that holds the arms in place. You then have minimal toe and camber control. Lower it and then weld the adjustments where needed.
or, buy a Z32/Z33 for a higher tech suspension and toss the 280ZX
Thanks. Kinda what I thought but had not found where it had been addressed. I've gone to a lot of trouble reinforcing everything to make it a convertable and adding a LS1 and I don't want to finish and find the rear suspension to be a dissapointment.
convertable? mmmmmm...... idk, ls1 sounds fun though. this has been brought up, it would take some time and money to fab up the Z parts to it but obviously its already been covered. best bet would to just upgrade whats already in there
the zx has good suspension for what it is. if you throw a ls1 and put other goodies on it that rear will be all over the road. i know someone who has done a 300zx suspension setup like bleach said.
The stock rear suspension is fine if its reconditioned and good dampers and springs used, don't forget its a similar type of suspension used on 510's and BMW's of that era.
Or maybe look at using the Z31 rear end? That would be my choice, five stud wheel conversion if you want it too.
Anyway, look at this BMW in action, see what you think http://www.youtube.com/watch?v=SiBoP7tcG_s
Then there is this sort of thing http://www.redz31.com/pages/coilovers.html
I'm sorry..but the convertable part...Made me puke in my mouth... In my opinion...the Z's in general..especially the 280zx's look like a crappy early 80's Mercedes Benz..when turned into a convertable.. No offense though man...just my opinion..
260DET,
I'll check those out. I've had to change gears a little to get the 240Z ready for Z Dayz so I've still got time to make some decisions. I know the diff will be my weak link. If I stay stock, I might have to make a new choice a mile or two down the road.
WildmaN,
No offense meant or taken but the ZX Spyder can look good and I can't stand T-tops and sun roofs.
And to be fair, I'm changing the nose and tail and the whole interior so that it will not have the "after thought" look I think you're talking about with the Mercedes.
WildmaN,
^^^ That one & his other yellow 280zx are both quite wild cars!
Originally Posted by johncdeere
How can I contact him?
bojo68
07-26-2009 02:23 AM
KurumaZ
FS: 300ZX (90-96)
05-17-2005 12:11 AM
SwiggA88zxt
12-01-2003 04:06 PM
haktmal
04-30-2003 12:10 PM
