1982 280ZX non-turbo
Old 05-24-2010 | 11:28 AM
Lostsoul's Avatar
My Dad handed down to me my uncles 1982 280ZX bought off the line. One of two things happen when I try start it. It will either start and run till it gets to running temp and then die and then it won't turn over, or it just won't turn over. I've changed relay switches, fuel pump, fuel filter, spark plugs, spark cables. I cannot find the problem. Any suggestions???
Old 05-24-2010 | 12:12 PM
Welcome to ZDriver and to owning a Z!
A motor needs 3 things to start:
-Proper air
-Proper fuel
-Proper spark
When it's having the starting issue, does it have spark? Does it have fuel?
Old 05-24-2010 | 12:24 PM
Lostsoul's Avatar
Thank u Nismopick. It does have fuel and spark. I am going to change the whole distributor next, after that I think the only thing I can change is the ECU.
Old 05-24-2010 | 12:35 PM
I would check the AFM, TPS, Ignitor, and CHTS, and each connector, before anything else.
Old 05-24-2010 | 02:10 PM
Lostsoul's Avatar
I will try that first. Mahalo
Lostsoul's Avatar
P.S. I did change out the AFM already. That was my first change
Old 05-31-2010 | 06:11 AM
zero's Avatar
So dont keep guessing and buying parts. You could have bought some diagnostic tools with that money. Do some tests. Find out whats wrong. Ask how to test spark or air and fuel if you dont know. Or you might as well throw away 300 dollars and enjoy your new lawn art.
char730
08-27-2014 05:49 PM
ThaPimpShrimp
01-06-2012 04:35 PM
MikeB7283
05-19-2011 12:23 PM
mickey_bigdaddy
05-12-2009 08:52 AM
280zExTURBO
10-10-2005 09:45 PM
Quick Reply: 1982 280ZX non-turbo
