1982 280zx turbo auto to manual swap
Hi new to the forum,
Me and my dad are currently working on our 1982 datsun 280zx turbo and the time has come to swap out trannys. My dad had planned on doing this long ago so in preparation he bought a brand new borg warner t5 from nissan in 1984 he also got a peddel box and clutch master cylinder. My question is what exactly has to be doen for this swap i know something has to be done for the drive shaft and the diff? I have been searching around and cannot find clear instructions on what needs to be done, so if someone can please tell me what has to be done for the swap it would be much appreciated.
-Andrew
-Andrew
-Andrew
Thanks nismo! after reading all of those threads i still couldn't find an answer lol. the only real concern i have is do i need to get a r200 diff and do i just need to shorten the existing drive shaft? Is the rear flange the same in my existing drive shaft as the one on the r200?
-Andrew
-Andrew
You don't need a new diff, just the output drive shaft as the T5 output is a diff spline count than the Nissan 5sp.
You need the BW T5 drive shaft and matching diff flange. And unless you want to do a bit of custom wiring, you will also need the body (chassis) side of the transmission harness.
-Andrew
aye aye aye...
Nissan ONLY used Borg Warner T5 transmissions for the manual 280zxt. Unless someone removed the T5 and swapped in the n/a trans, all manual 280zxt's have the T5.
To reiterate, there are TWO factory transmission options for the 280zxt:
-3speed Auto
-BW T5 Manual
Re-read this:
-3speed Auto
-BW T5 Manual
Re-read this:
aye aye aye...
-3speed Auto
-BW T5 Manual
Re-read this:
-3speed Auto
-BW T5 Manual
Re-read this:
You need an entire parts car for the drive shaft?
I suggest checking our classifieds first (there just happens to be several 280zxt part outs):
https://www.zdriver.com/forum/forumdisplay.php?f=242
Anything is possible.
$620 to Nissan and it's yours!
http://www.courtesyparts.com/propeller--p-349808.html
$849 for an MSA aluminum one:
http://www.thezstore.com/page/TZS/PROD/22-1037
$229 for an MSA reman (if in stock):
http://www.thezstore.com/page/TZS/PROD/22-1023
Turbo automatic trans spline count
Question, is the spline count on the ZX-Turbo automatic trans the same as the 5/speed spline count ? I just swappped out a 1979 ZX automatic trans for a 1982 automatic trans, and the spline count on the new automatic trans does not fit the original drive shaft. Does anyone know about this ? Thank you.
borini63
76
06-29-2013 07:27 PM
tim400
09-29-2012 10:04 AM
Superduner
11-08-2009 04:44 PM
