1983 280ZX battery was connected backwards. HELP!!!!!!
I have been on deployment and i asked my brother inlaw to charge the battery and when he reconnected the battery to start the car, unfortunaly it was connected wrong and fried something. Any ideas as to where i start to troulble shoot.
Welcome to ZDriver! ![006](https://www.zdriver.com/forums/images/smilies/006.gif)
So the car doesn't start? Does it have power?
He most likely fried the fusible links and/or the ecu (computer). Check the links & fuses... if they are good, swap in another ecu.
Second: Check the ECU, if it wasn't too long ago you should be able to smell if it was what was burning. If it isnt the ECU, listen to NismoPick as i'm out of ideas.
Edit: if it is your ECU I have a 280zx ECU, for a turbo I think, I'll have to check the number on it.
Third: Welcome to Zdriver
someone did this to a 280ZX I had.
In the end, one of my relays was bad and had to be replaced. It was one of the five that are in a plastic box in front of the right strut tower. Otherwise, just a fusable link.
300zx1990z32
05-09-2011 07:38 AM
chrischicoine18
05-12-2006 10:18 AM
