280ZX low end power loss
Old 12-03-2003 | 08:32 AM
Distributor
Maybe your distributor has shifted a little. Loosen that little screw by the base and turn the distributor clockwise just a tad. Or possibly your vaccume advance is getting sticky as most distributors on these Z's tend to do. I gained a lot of low and midrange power by swaping out my distributor for one with a properly functioning vaccume advance.
If your power loss is over a long period of time, it could just be the timing chain stretch but you haven't had your Z that long.
Old 12-08-2003 | 02:06 PM
Maybe when you put your cold air intake on, you got an air leak somewhere on one of those boots. If you have an air leak after the Air Flow Meter it will show up as a lean mixture untill you've gained enough rpms so that the small leak doesnt' make that much of a difference.
Old 12-09-2003 | 08:06 PM
craZed's Avatar
have u checked ur timing
Old 12-10-2003 | 04:44 PM
Jimmys83Z's Avatar
I would check tps as well as dis. and vac. adv. and fuel pressure
Old 12-11-2003 | 06:00 AM
Fredrik's Avatar
It sounds lika there´s something with the AFM, try cleaning it. Does it run like normal on idle? I don´t think its the timing chain because it usually mean top-end power loss.
vg30de
06-11-2013 10:53 PM
Fozy
03-28-2011 07:42 PM
mikesz
05-29-2008 11:06 AM
Cw2435
01-18-2004 05:29 AM
280zdriver_16
01-09-2004 10:39 AM
Quick Reply: 280ZX low end power loss
