79 280 ZX only starting gives an issue
Old 01-05-2015 | 02:11 PM
1979 280z's Avatar
After the z warms up it is fine. I have to feather the gas to get it to start for about 3 mins and hope it doesn't die to start the feathering all over again. I just swapped the motor and the old one didn't do this. Seems like the fuel light wants to bounce off and on when I am trying to start. Any help appreciated.
Old 01-05-2015 | 02:58 PM
zxguy1986's Avatar
Welcome to ZDriver!
Wish I knew more about the S130 but if you had a Z31, I would suggest you check out the air regulator for the 2 solenoids which control your idle speeds, cold and fast. Let our S130 guys give you their input. Sounds like a common issue and probably has an easy solution.
If you don't already have your freebie factory service manual and the other cool docs available at XenonS130 - S130 Reference download them and check them out. Your FSM has a lot of easy to follow inspection and troubleshooting pages that may be of some help while you are waiting for other suggestions.
Thanks and welcome again.
Unorthodox
10-11-2013 11:15 AM
GreenMachine
07-29-2012 08:09 AM
Lesnocker
02-11-2011 01:13 PM
OpenRange
08-26-2009 12:54 PM
280z racer
09-25-2007 11:29 AM
Quick Reply: 79 280 ZX only starting gives an issue
