79 ZX Won't Start
Old 02-13-2005 | 05:02 PM
swmoman's Avatar
79 ZX Won't Start
I have this old lady that is need of some major TLC. But here is my problem.. It has been sitting for 10 years. It was parked because it quit running and no one ever tried to fix it. I have spark but it appears that I am not getting fuel. How do I check to see if the pump is working? How do I tell if the injectors are working?
I loosened the hoses on the fuel line. The filter is passing gas through it but nothing is coming out of the lines when I turn over the motor..
Does anyone have any suggestions?
Thanks I appreciate any help you can give me.
Last edited by swmoman; 02-13-2005 at 05:03 PM. Reason: my horrible typing and spelling
Old 02-13-2005 | 05:31 PM
crazytvrguy280's Avatar
ok it has gas come out of the line or not and if ther is gas then try to start it with sarter flued cas that is how i got mine runing after it sat for about 8 years o and drop you tank first and drain the gas or you will plug and injectors i made the mistak when i did it o i have really bad spelling
Old 02-13-2005 | 05:33 PM
o and blow out you line to
Old 02-14-2005 | 03:40 PM
EatmyDust's Avatar
starting fluid
if you get in the bad habit of using starting fluid too often, your car wont start so quick latter down the road, it forms like a cruch for the engin if you will. but yea it might help at first. after you have your tank cleaned go to Napa and get a can of sea foam gas treatment to put in the tank with the gas to clean out any of the trash that might have made it thoug. bare in mink seafoam is a highly potent cleaning substance, if you do get it runing, the seafoam will nock all that trash out and it may start runing like **** for a will do to the trash being nocked loos. so be ready for some good old cleaning.
Old 02-14-2005 | 03:59 PM
Buy a new filter or temporarily bypass the filter. run the fuel line past the filter straight to the fuel rail.
Don't drive like that, just try it to see if it starts up. Maybe use starting fluid too.
Later on, put in new fuel hose (for fuel injection, not cheap carb line) a new filter, and new spark plugs. You should not need starting fluid with that.
zcooks
04-11-2016 07:36 AM
bongpogi
08-19-2015 12:15 PM
moorebl
04-14-2011 04:28 PM
bardabe
09-21-2004 04:12 PM
