81 280zx no turn signal flasher
Hi, I have hazards and the flasher is only connected to the hazard, but no turn signals. When I put the test light on the fuse for the turn signals it sparks and makes a clicking noise under the dash by the fuse box. I can't seem to see the flasher for the turn signals or even a connector. The p.o. really did a number on the wiring on my 81 280zx. Any help is greatly appreciated! Thank You, Pam
Oh and I do have hazards. All bulbs are good. Hazard switch is turned all the way off.
So a dirty connection caused the problem, if you didn't protect the connector in anyway then odds are the problem is going to happen again, put a little bit of vasoline between the connectors to protect the contacts from the elements.
