81 zx engine swap elec. issue no CHTC
Don't quote me, because im not sure if its the right thing to do, i had to run my Cht up to the cts in the thermostat housing. from what i under stand (someone correct me if im worng please) the ecu interpits the signal the same, but you have to make sure the correct sensor is in the correct hole. my car runs fine after i extended the wires.
